Can One Telescope Do It All? A Beginner’s Guide to Visual Astronomy and Astrophotography
One Telescope for Both Visual Astronomy and Astrophotography?
“I want to buy a telescope to observe planets, the Moon, and deep-sky objects, and also use it for astrophotography. What is the best telescope I can buy under ₹25,000?”
This is a question frequently asked by newcomers to the hobby in the Chennai Astronomy Club WhatsApp group. This post aims to address that question and help beginners make an informed decision before spending their money.
A quick background
As discussed in our forum post, As a beginner, what telescope or binocular should I buy?, we generally recommend starting with a good pair of 10×50 binoculars. Once you become familiar with the night sky, a 6-inch to 8-inch Dobsonian telescope is the next logical step. A good Dobsonian can serve you for a lifetime.
However, a quick online search will bring up plenty of inexpensive refractors and reflectors bundled with alt-azimuth or equatorial (EQ) mounts. These mounts typically come with tripods, making the packages look like complete, ready-to-use astronomy setups.
Many beginners do some preliminary research, see that an EQ mount is designed to track the sky as the Earth rotates, and conclude that it must be suitable for astrophotography.
Unfortunately, that assumption can lead to an expensive disappointment.
Many inexpensive telescope-and-mount packages compromise heavily on mount stability. Even a reasonably good telescope can become frustrating to use when paired with a poor mount. Excessive vibration makes focusing difficult and can render the telescope practically unusable, even at relatively low magnifications.
An equatorial mount is not inherently unsuitable for visual observation. In fact, a good EQ mount can work well for both visual astronomy and astrophotography. The problem is that the inexpensive mounts bundled with many entry-level telescopes are often too flimsy for either purpose. Furthermore, EQ mounts can place the eyepiece in awkward positions, making visual observing less comfortable.
So, what should you buy?
What is best for visual astronomy?
A good pair of 10×50 binoculars is an excellent starting point. You can use them to explore brighter celestial objects from the city, and they become even more rewarding under dark skies.
If you want to move up to a telescope, a Dobsonian is generally considered one of the best value-for-money options for visual astronomy. The term Dobsonian refers to the mount design, while the telescope itself is almost always a Newtonian reflector.
Dobsonians offer relatively large apertures for their price, allowing you to observe the Moon, planets, star clusters, nebulae, and galaxies. Their simple, stable mount design also makes them easy to set up and use.
At the time of writing, a decent 6-inch Dobsonian costs around ₹31,000, putting it slightly above the ₹25,000 budget in our original question.
What about astrophotography?
If you already own a DSLR or mirrorless camera, you can capture some excellent photographs of the Moon and try basic planetary imaging with a suitable telescope. Some beginners have also managed to photograph bright planets such as Jupiter and Saturn using their smartphones.
However, a conventional Dobsonian mount does not track the sky automatically as the Earth rotates. You can still experiment with lunar and planetary photography, but long-exposure deep-sky astrophotography requires a different approach. Without tracking, celestial objects drift across the field of view, making it difficult to capture the long exposures needed for faint nebulae and galaxies.
What do you need for astrophotography?
There is a common saying among astrophotographers: the mount is the most expensive part of your entire setup.
For deep-sky astrophotography, a suitable tracking mount is one of the most important investments you can make. Depending on your goals, you may also need a telescope or camera lens, an astronomy camera or DSLR/mirrorless camera, a guide scope, a guiding camera, and other accessories.
These components add up quickly. A setup capable of producing good deep-sky images can cost considerably more than ₹25,000, particularly if you are starting from scratch.
It is also worth remembering that visual astronomy and astrophotography place different demands on your equipment. Visual observers generally benefit from a larger aperture, while deep-sky astrophotographers need accurate tracking, good optics, and a stable imaging setup. A telescope that excels at one does not automatically excel at the other.
Admittedly, experienced visual observers do use their good quality EQ mounts for observing the sky with high quality refractors or other types of telescopes. But that is a topic for another day.
In a nutshell
There is no single ideal setup that excels at both visual astronomy and deep-sky astrophotography that falls within a tight budget.
If you are a beginner trying to decide between the two, my advice is simple: prioritise what you want to do most.
If you are new to astronomy, I would personally recommend starting with visual observing. Learn to navigate the night sky, explore it with binoculars, and eventually invest in a good Dobsonian telescope. You can also skip the binoculars and go directly to a telescope. Enjoy the experience, discover which objects interest you most, and give yourself time to understand the hobby.
You can always save up for a dedicated astrophotography setup when you are ready to take that next step.
There is no need to rush into buying equipment that promises to do everything but does neither particularly well. Enjoy the night sky first. The photographs can come later!
These thoughts come from a person who is more biased towards visual observing but has spent a lot more on astrophotography gear :blush:.
