Hi everyone…I recently bought a 12 inch skywatcher goto dobsenian scope. Just not able to figure out how to watch planets. The best I could do is looking at the moon
. Below are the eye pieces that I have.
- 0.10 mm
- 0.25 mm
- 0.42 mm
- ED Barlow
Can you please elaborate on why you are not able to observe the planets?
Frankly I don’t even know which eye piece to use and how to focus
Since you have a go-to system, once it is set-up and aligned, you can dial-in the target (say, Jupiter) and then telescope finds it for you. Use the 42 mm eyepiece first since it has the largest FOV to make sure the object is centred in the FOV of the eyepiece. Then you can change eyepieces or add a barlow to achieve a higher magnification. And you have to refocus whenever you change eyepieces or add a barlow.
At first I am doing an alignment based on moon. Once my alignment is successful, later I am asking the hand held device to focus on Jupiter. However once the telescope moves towards Jupiter, I am not able to find it. I even try to manually search. However no luck
Jupiter is a bright planet. It is visible to the naked eye. Try manually finding it with the finderscope of your telescope and then look into the eyepiece (use the 42mm). Your finderscope needs to be aligned with the telescope’s view for this to work. Apps like stellarium, skysafari etc., will help you to find the general position of your target.
Use the sky guide app to find the planet coordinates, and then use the telescope and zoom into them. The sky guide app is one time payable 179 INR. But it’s worth it. It gives you an idea of the coordinates and a virtual presentation of them in the app. All the best.
Here’s what I would recommend.
