As a beginner, what equipment should I buy?
A Practical Guide to Buying Your First Astronomy Gear in India
Getting started with observational astronomy can be exciting, but beginners often face one common question: What equipment should I buy first?
The right choice depends on your budget, observing conditions, portability needs, and whether you plan to upgrade later. This guide covers two practical entry options that we recommend for beginners based on our experience: 10×50 binoculars and beginner Dobsonian telescopes.
1. 10×50 Binoculars
For many beginners, 10×50 binoculars are one of the simplest ways to start exploring the night sky. They are lightweight, easy to use, and require almost no setup. You simply point them at the sky and start observing.
Recommended Models
  • Nikon Aculon 10×50
  • Olympus 10×50 (older models are known for very good optical quality; the newer models should be checked before buying)
Useful Accessories
Although binoculars can be handheld, a monopod or tripod adapter can greatly improve the observing experience. At 10× magnification, hand shake becomes noticeable during longer viewing sessions.
It is also important to note that observing objects close to the zenith (directly overhead) can be uncomfortable because you will need to tilt your head back for extended periods.
What You Can See
With 10×50 binoculars, you can observe several interesting celestial objects:
  • The Moon, including many craters and surface features
  • Jupiter, along with its four Galilean moons(but very little surface details on Jupiter will be visible)
  • Saturn, where the rings may appear as a slight elongation or hint of structure (a tripod helps here)
  • Venus, showing its phases
  • Open star clusters, which often look spectacular through binoculars
  • Nebulae, galaxies, and globular clusters, especially under dark skies
However, spotting faint objects from a city environment with significant light pollution can be challenging and often requires some experience.
When to Buy Binoculars
Binoculars are a good option if:
  • Your budget is strictly below ₹15,000
  • You want something simple and quick to use
  • You have other hobbies such as birdwatching or wildlife observation, where binoculars can also be useful
When Not to Buy Binoculars
Binoculars may not be the best choice if:
  • You want a one-time purchase and do not plan to upgrade later
  • You are primarily interested in planetary detail
In those cases, investing in a telescope around ₹25,000 or more may be a better long-term decision.
2. Telescopes
If you want to see more detail on planets and deeper views of faint objects, telescopes offer a significant upgrade over binoculars.
Two practical beginner options are tabletop Dobsonian telescopes and full-size Dobsonian telescopes.
Bresser Messier 5" Tabletop Dobsonian (~₹26k)
The Bresser Messier 5-inch tabletop Dobsonian is a compact reflector telescope designed for portability and ease of use.
Please note that we are explicitly mentioning the brand here because we have some experience with this telescope.
Because it is a tabletop telescope, you will need a stable table or stool to place it on during observations.
When to Buy
This telescope can be a good choice if:
  • The observer cannot comfortably lift heavier telescopes (for example, children or seniors)
  • You mainly observe from balconies or small spaces
  • You do not own a car to transport larger telescopes
  • Your budget is under ₹30,000
  • You cannot invest significantly more in upgrades later
Compared to binoculars, this telescope provides better views of planets and many deep-sky objects.
Possible Limitations
  • The finder scope may need replacement or upgrading
  • You must have a stable platform such as a table or stool
8-Inch Dobsonian Telescope (~₹42k)
An 8-inch Dobsonian telescope is often considered one of the best value telescopes for serious beginners. Its large aperture gathers significantly more light, allowing you to see more detail and detect fainter objects.
When to Buy
A telescope in the 6–8 inch range is recommended if:
  • Your budget is at least ₹35,000
  • You have space to store the telescope
  • You are comfortable carrying components that weigh around 9–12 kg each (the base and the optical tube)
  • You have access to a terrace or outdoor observing area
  • You can occasionally travel to darker skies
Transporting an 8-inch Dobsonian usually requires a car, and smaller cars may require folding the back seats.
When Not to Buy
This telescope may not be suitable if:
  • You cannot carry heavy equipment
  • You live in a building with many floors and no lift
  • You are unable to travel to darker observing locations
From heavily light-polluted cities, observations will mostly be limited to:
  • The Moon
  • Planets
  • Double Stars
  • A few brighter deep-sky objects like some bright nebulae, open clusters, some globular clusters, bright comets.
Final Thoughts
Choosing between binoculars and a telescope depends mainly on budget, portability, and long-term interest in the hobby.
A simple guideline is:
  • Under ₹15,000: Start with 10×50 binoculars
  • ₹25,000–₹30,000: Consider a 5-inch tabletop Dobsonian telescope
  • ₹35,000 or more: A 6–8 inch Dobsonian telescope offers the best long-term performance
For many beginners, starting with binoculars is a great way to learn the night sky and build observing skills, after which upgrading to a telescope becomes a much more rewarding step.
Credits to @vijay , @linusnelson , and @parthiiban for their inputs.
Adding my 2 Cents..
What not to buy:
One might get deceived by advertisement the moment you start searching for telescope, especially during any Astronomical events. Telescope dealers run campaigns to draw your attention to products that are often hobby killers !
Products to Avoid:
  • Astromaster 130EQ: : Reason - Poor optics, wobbly mount. Extremely bad focuser, If you are planning for lunar/planet photography by attaching DSLR/Planetary Cam the Focuser tends to sag and affects collimation big time and most important factor it does not come with Parabolic mirror, even though it is advertised so..(One can verify the official datasheet from manufacturer). These days it costs around 22K, adding extra 3k will get you a decent 5" or 6" DOBs which can last for ages.
  • 50 AZ, 60AZ, 70AZ, 80AZ etc.. Stay away from Alt-Az mount which cannot hold the telescope steady and a tiny gust of wind will shake it crazy and takes ~15 Seconds to settle ! they often come with 0.95" eye piece and puts strain to your eye during prolonged observation.
  • Telescopes advertised with fancy Jargons " Telescope with 100x, 150x Ultra Zoom | Fully Coated Glass Optics" | “Useful for detailed planetary study” | “Travel-Friendly Design” | “High Magnification”
Always look at the technical product specification available on the manufacturer website and don’t rely on e-commerce description which are often exaggerated.
What to Buy vs. What to Avoid
Stepping into amateur astronomy in India can feel like navigating a minefield. The Indian market is flooded with flashy advertisements, tempting online listings, and prices that seem too good to be true. Unfortunately, many beginners end up with an expensive “hobby killer”—a telescope so frustrating it ends up gathering dust in a closet.
To help you get the best views of the night sky without wasting your hard-earned money, here is a straightforward breakdown of what to buy and what to avoid in the Indian context.
:green_circle: What to Buy: The Safe Bets
When investing in a telescope, you want your money going into high-quality optics and stable mounts, not marketing campaigns. These brands deliver real performance.
1. Anything GSO (Guan Sheng Optical)
If you want the absolute best value for your money, look for GSO. This Taiwanese company is a true Original Equipment Manufacturer (OEM), meaning they design and build their own optics from scratch rather than outsourcing.
  • Why buy: Because they eliminate the middleman, their telescopes offer unmatched performance per rupee.
  • The Verdict: GSO Dobsonian telescopes are widely considered the gold standard for amateur astronomers in India. They are simple to use, incredibly stable, and offer massive apertures for viewing deep-sky objects.
2. Bresser & Explore Scientific
Both Bresser and Explore Scientific share the same manufacturing roots in China, offering premium build quality and excellent design.
  • Why buy: While they do command a higher price tag in India due to import dynamics, the premium is often worth it for the mechanical and optical refinement.
  • The Verdict: Their telescopes are highly reliable, but their Explore Scientific eyepieces are the real stars—offering roughly 85% of the performance of the world’s most elite luxury brands at a mere fraction of the cost.
3. Sky-Watcher & Celestron (Choose Wisely)
Both of these massive brands are owned by Synta, a manufacturing giant. Celestron, in particular, is incredibly popular in India. However, because their catalogue is so massive, they sell some of the best equipment on the market—and some of the absolute worst.
  • What to buy: Celestron’s Schmidt-Cassegrain Telescopes (SCTs) are the undisputed industry benchmark for planetary viewing and astrophotography. However, because they are complex and expensive, they aren’t ideal for absolute beginners.
  • What to avoid: Completely steer clear of the PowerSeeker and AstroMaster entry-level lines. They suffer from wobbly mounts and flawed optical designs.
:red_circle: What NOT to Buy: The “Hobby Killers”
Avoiding the wrong telescope is just as important as finding the right one. If a deal looks too good to be true, it almost always is.
1. No-Name Online Scopes & Low-End Indian Brands
The easiest rule of thumb is to avoid the flood of generic, no-name telescopes found on major e-commerce platforms, as well as most cheap Indian-branded scopes.
  • The Reality: These are not engineered by the companies selling them. They are cheaply mass-produced plastic tubes imported from overseas with a local brand sticker slapped on the side.
  • The Exception: This isn’t anti-local bias; it’s about quality control. In fact, homegrown makers like Aperture Telescopes—who actually grind and polish their own optics right here in India—have a great reputation among enthusiasts.
2. Social Media Hype Trains
As a rule of thumb, reputable, high-quality telescope brands rarely advertise on social media.
  • The Reality: If you see a telescope being aggressively pushed via Instagram or Facebook ads, it is a red flag. It usually means the company excels at marketing, not optics. The premium price you are paying is funding their ad budget, leaving you with subpar glass and a shaky tripod.
The Bottom Line
For a beginner in India, a GSO Dobsonian remains the smartest, most rewarding entry point into the hobby. Keep your budget focused on the glass, avoid the flashy social media ads, and stick to trusted manufacturers who build their own optics. Happy stargazing!
To add a few more pointers if you are a beginner:
  1. Finder Scopes: Avoid telescopes that rely solely on a basic red-dot finder. While red-dot finders aren’t completely useless, a traditional optical finder scope makes locating objects considerably easier for a beginner by gathering more light and showing exactly where your telescope is pointed.
  2. Focusers Matter: Be cautious with telescopes priced under ₹50k that use cheap rack-and-pinion focusers. Inferior focusers have too much play and slop, making sharp mid-to-high-power focus nearly impossible—even if the main optics are solid. Look for a Crayford-style focuser instead (or verify the focuser quality before buying). High-end telescopes do feature excellent, buttery-smooth rack-and-pinion focusers, but budget versions are almost always a bottleneck.
  3. Future-Proof with a 2" Focuser: Even if you don’t own any 2" eyepieces today, avoid buying a telescope locked to a 1.25" focuser barrel. A 1.25" drawtube acts as a physical bottleneck that restricts your true field of view. When you eventually want sweeping, immersive views of large targets like the Andromeda Galaxy or Pleiades, a 1.25"-only focuser will block you from using 2" wide-field eyepieces.
